Ultimate smart home front porch security.
14-Day Cloud Storage
Subscriber Discount
Low stock: 100 left
Meet the ultimate smart home front porch security bundle. With Wyze Video Doorbell and Chime, view your front porch in 1080p HD and say hello with two-way audio. With Wyze Lock, unlock and lock the door remotely and view your lock history in the Wyze app.
View your porch in 1080p HD
Lock/unlock the front door remotely
View motion events and lock history
Works with Alexa and Google Assistant
Wyze Video Doorbell
- Power: 16V-24V AC, ≥10VA (May use existing doorbell-chime circuit, or standalone transformer and wires.)
- Weight: 1.7oz / 49gSize: 1.5'' x 3.25'' x 0.625''
- Image Sensor: 2K (2048 x 1536)
- Camera: F2.0 aperture, 2.7mm focal length, 1/2.8" CMOS
- Image Quality: 1080p and 480p w/ 8x Digital Zoom
- Frames per Second: 20 Daytime, 15 Nighttime
- Audio: Built in Speaker & Microphone (with 2-way Audio & Noise/Echo Cancellation)
- White LED (Fill Light): 6 x 5000K (daylight color temperature)
- IR Night Light: 4 x 940nm Infrared LED
- Connectivity: Direct to WiFi 802.11 b/g/n, 2.4GHz (5GHz WiFi not supported)
- Sub1G: 906.8MHz, used for local connection between doorbell and chime.
- IP65 Weather-resistant
- Storage Temperature: -40 to 176°F (-40 to 80°C)
- Operating Temperature: -4 to 122°F (-20 to 50°C)
- Field of View: 120° Vertical x 88° Horizontal
- Operating Systems: iOS 9.0 and Android 5.0 or later
- Data Security: End-to-end encryption, HTTPS secure transfer protocol, AES 128-bit encryption
Wyze Chime
- Chime Power: Standard US Power Outlet: 100V-240V, 0.1A, 50/60Hz
- Weight: 2.0 oz / 56g
- Size: 2'' x 2'' x 1.4''
- Chimes: 5 modern, 4 classic doorbell, 3 animal sounds, 6 automation sounds, 1 intruder alarm
Lock
- Color: Silver
- Dimensions: 4.9" Length x 2.5" Width x 1.3" Depth (2" including knob)
- Weight: 0.67 lb
- Power Source: 4x AA Batteries (included)
- Battery Life: 5-6 months (depending on usage)
- Communication Method: Bluetooth, Zigbee
- Range: To Keypad: 9', To Gateway: 50', BLE to phone: 16'
- Compatibility: Android 5.0+, iOS 9.0+
- Weather Resistance: Indoor only
- Operating Temperature: 14°F - 131°F / -10°C - 55°C
- Storage Temperature: -22°F - 158°F / -30°C - 70°C
Keypad (sold separately)
- Color: Silver
- Dimensions: 3.7" Length x 1.3" Width x 1.0" Depth
- Weight: 0.1 lb
- Power Source: 2x AA Batteries (included)
- Battery Life: 4-6 months (depending on temperature)
- Range: To Lock: 9'
- Weather Resistance: IPX5
- Operating Temperature: -4°F - 140°F / -20°C - 60°C
Gateway
- Color: White
- Dimensions: 2.1" Length x 2.1" Width x 1.2" Depth (1.9" including pins)
- Weight: 0.12 lb
- Power Source: 110-240V, ~60Hz
- Battery Life: NA
- Communication Method: Bluetooth, Zigbee, Wifi
- Range: To Lock: 50', To Router: 50
Wyze Lock
- Wyze Lock x1
- Wyze Lock Gateway x1
- AA Batteries x4
- Adhesive Strip x1
- Mounting Plate x1
- Adapter x3
- Quick Start Guide x1
Wyze Video Doorbell + Chime
- Wyze Video Doorbell x1
- Wyze Chime x1
- Wall Plate x1
- Wedge (Horizontal, 30°) x1
- Wire Caps x4
- Bracket Screws x2
- Screws & Expansion Tubes x2
- Extension Wires x2
- Fuse x1
Did you know?
You can lock/unlock the door right from the Wyze Video Doorbell (or Video Doorbell Pro) viewer. Watch the video to see how simple it is.
